- Parent Category: Power Systems
- Category: Power Flow Test Systems
- Hits: 77785
14-Bus System (IEEE Test Case)
I. Introduction:
\(\bullet\) The IEEE 14 Bus Test Case represents a portion of the American Electric Power System (in the Midwestern US) as of February, 1962. A hardcopy data was provided by Iraj Dabbagchi of AEP and entered in IEEE Common Data Format by Rich Christie at the University of Washington in August 1993.
\(\bullet\) This test case consists of 14 buses, 5 generators and 11 loads. The 14 bus test case does NOT have line limits. Compared to 1990's power systems, it has low base voltages and an overabundance of voltage control capability.
II. Single-Line Diagram:
\(\bullet\) The original diagram is available in III.
III. Files:
\(\bullet\) Original Diagram (600dpi, TIFF Format) [Download]
\(\bullet\) Modified Diagram (PDF Format) [Download]
\(\bullet\) IEEE Common Data Format (CDF Format) [Download]
\(\bullet\) Extended Information (PDF & TEXT Formats "Russian Language") [Download]
\(\bullet\) PowerWorld Simulator [Download]
\(\bullet\) DigSILENT PowerFactory (v. 15.2.2) [Download]
\(\bullet\) MATPOWER [Download]
\(\bullet\) Mathworks MATLAB [Download]
\(\bullet\) Mathworks Simulink [Download]
\(\bullet\) Microsoft Excel Based Application [Download]
IV. Citation Policy:
If you publish material based on databases obtained from this repository, then, in your acknowledgments, please note the assistance you received by using this repository. This will help others to obtain the same data sets and replicate your experiments. We suggest the following pseudo-APA reference format for referring to this repository:
Ali R. Al-Roomi (2015). Power Flow Test Systems Repository [https://al-roomi.org/power-flow]. Halifax, Nova Scotia, Canada: Dalhousie University, Electrical and Computer Engineering.
Here is a BiBTeX citation as well:
@MISC{Al-Roomi2015,
author = {Ali R. Al-Roomi},
title = {{Power Flow Test Systems Repository}},
year = {2015},
address = {Halifax, Nova Scotia, Canada},
institution = {Dalhousie University, Electrical and Computer Engineering},
url = {https://al-roomi.org/power-flow}
V. References:
[1] Rich Christie, "Power Systems Test Case Archive," Aug. 1993, [Accessed Feb. 4, 2015]. [Online]. Available: http://www.ee.washington.edu/research/pstca/pf14/pg_tca14bus.htm
[2] Sameh Kamel Mena Kodsi and Claudio A. Canizares, "Modeling and Simulation of IEEE 14-Bus System with Facts controllers", University of Waterloo, E&CE Department, Technical Report #2003-3, [Accessed Mar. 20, 2015]. [Online]. Available: https://ece.uwaterloo.ca/~ccanizar/papers/IEEEBenchmarkTFreport.pdf
[3] M. V. Khokhlov, "Test Circuit (translated from Russian language: Тестовые схемы)," 2008 [Accessed Mar. 24, 2015]. [Online]. Available: http://energy.komisc.ru/dev/test_cases/
[4] The Illinois Center for a Smarter Electric Grid (ICSEG), "Power Cases," [Accessed Feb. 4, 2015]. [Online]. Available: http://publish.illinois.edu/smartergrid/case-2-ieee-14-bus-systems/
[5] Francisco M. Gonzalez-Longatt, "IEEE 14 Bus Test - DigSILENT: Original Example provided by PowerFactory," [Accessed Mar. 16, 2015]. [Online]. Available: http://www.fglongatt.org/Test_Systems/IEEE_14bus_PF.html
[6] Ray D. Zimmerman, Carlos E. Murillo-Sánchez and others, "MATPOWER: A MATLAB Power System Simulation Package," [Accessed Mar. 21, 2015]. [Online]. Available: http://www.pserc.cornell.edu/matpower/
[7] Saloman Danaraj, "Power Flow Software in Rectangular Coordinates," Mathworks Simulink File Exchange Center, May 2008, [Accessed Mar. 16, 2015]. [Online]. Available: http://www.mathworks.com/matlabcentral/fileexchange/19961-power-flow-software-in-rectangular-coordinates
[8] Bharath Y.k., "IEEE 14 Bus System," Mathworks Simulink File Exchange Center, Mar. 2014, [Accessed Mar. 16, 2015]. [Online]. Available: http://www.mathworks.com/matlabcentral/fileexchange/46067-ieee-14-bus-system
[9] K. S. Sastry Musti and Ricardo B. Ramkhelawan, "Power System Load Flow Analysis using Microsoft Excel," Spreadsheets in Education (eJSiE), Vol. 6, No. 1, pp. 1-19, Dec. 2012. [Online]. Available: http://epublications.bond.edu.au/cgi/viewcontent.cgi?article=1132&context=ejsie
